Hi All,
Faced such problem.
Activation of Detail view by double clicking makes it switch to the Shaded.
It works only once after file opening. All the other tries work properly.
Just in case, file is attached.
951.3dm (215.0 KB)
Hi All,
Faced such problem.
951.3dm (215.0 KB)
Hi Screamer -
I’m afraid that’s not something I can reproduce with that file and description.
Hi @wim ,
Well, maybe this video and SysInfo will help.
Rhino 8 SR11 2024-8-27 (Rhino 8, 8.11.24240.13481, Git hash:master @ b86341cde534cae6cae9bf38b1fc5368de3c5c8e)
License type: Commercial, build 2024-08-27
License details: Stand-Alone
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.0
Computer platform: DESKTOP
Primary display and OpenGL: Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 11-16-2022 (M-D-Y). OpenGL Ver: 4.6.0 - Build 31.0.101.2115
Secondary graphics devices.
NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 12-1-2023 (M-D-Y).
- There are no monitors attached to this device!
ATTENTION:
Desktop is using the slower, less reliable integrated graphics device and probably needs a configuration change.
There is only one monitor detected, but it’s connected to the slower, integrated graphics video port.
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 31.0.101.2115
Driver Date: 11-16-2022
Driver Version: 31.0.101.2115
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\ClippingBox (4dfff1df-5f09-43ae-a044-77b115244b02)\1.0.0.0\Rhino 6\ClippingBox.rhp “ClippingBox” 1.0.0.0
C:\Users\A\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\Iris\0.7.1\Iris.V7.rhp “Iris” 1.0.0.0
C:\Users\A\Scrips and plugins\V6\LayerRenameTools.rhp “Rhino.NET SDK” 0.0.0.0
C:\Program Files\Rhino 6\Plug-ins\DATAKIT\Rhino6_Import_x64.rhp “Datakit_to_rhino6”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24240.13481
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24240.13481
The openGL should be on the 16gb video card, currently it’s on the 1gb.
Check your cabling, device manager as well as the graphic settings.
Hi @Japhy
Yeah, already saw it and fixed.
Unfortunately this doesn’t help with the issue above.
Is this repeatable if you open up the file while Rhino is in Safe Mode? (search Rhino 8 in Safe Mode in windows start to initiate)
Does this only happen when running Revert or do you see this with Open as well?
No. Safe mode doesn’t repeat this issue.
Yes, Open makes the same result.
Ok. I tried to get rid of almost all of non-Rhino plugins.
Updated Nvidia drivers.
Still same result. Switching to Shaded when clicking a Detail.
The lates SysInfo below:
Rhino 8 SR11 2024-9-3 (Rhino 8, 8.11.24247.13001, Git hash:master @ c6461da0b1385d9760c58910e329a3e4a6297c06)
License type: Commercial, build 2024-09-03
.NET 7.0.0
Primary display and OpenGL: NVIDIA Quadro RTX 5000 (NVidia) Memory: 16GB, Driver date: 7-23-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 552.86
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-23-2024
Driver Version: 31.0.15.5286
Total Video Memory: 16 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.11.24247.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.11.24247.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.11.24247.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.11.24247.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.11.24247.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.11.24247.13001
Hi Screamer -
With the non-Rhino plug-ins disabled, can you make a new file from a factory-default template, add a layout with a detail, and reproduce that behavior in that new file? Or is this behavior isolated to that specific file?
Hi @wim ,
I don’t know why, but I still have the issue. ![]()
.NET 7.0.0
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Render version: 4.6
Hi @sysinfo,
I can repeat the issue.
I will get it logged for the developers.
I thought I was the only one.
Thanks,
Mary Ann Fugier
We also stumbled upon this yesterday and I was able to patch it up this morning.
