V8 Bug - Multiple Decals with Transparency/Instability
Ran into a bug with multiple decals on a polysurface with transparency enabled for one. Issue shows in both Rendered and Raytraced mode. Here it is with everything set at 0% transparent:
If I try adding a little transparency to the SONY logo, weird things happen:
Notice what’s happening to the color on “ONY”
Also to add - I’ve had more crashes in one afternoon using Decals in V8, than I think I’ve had in total using Rhino for the last 10 years. It’s massively prone to crashes - it’s literally save your file after every single decal, so you don’t lose work when it crashes. I’m on the latest release candidate.
ETA - It would be REALLY nice if the default behavior for Decals was for the widget to come up by default when they are added.
-Sky
Hi Sky - I am not seeing this but probably doing it wrong - can you apply these to a box or anything that shows the problem and post that file or send to tech@mcneel.com?, with a link back to this topic in your comments…
This project is just for fun, no reason I can’t post the original:
C9_FrontClip_DecalBug.3dm (7.5 MB)
I see the issue. I logged it as RH-80694 Other decal showing through when setting trasparency on decal
This is wonderful! I hope you are going to finish off the rest of the tutorials for this. :wink:
I definitely am. I decided to finish it first, then use it for a basis for lessons. Then life got professionally incredibly busy. I’m going to eventually post the simple OML for all the primary surfaces, and all the blends - minus things like the body panel splits and such. It’s really a lesson in patch layout and clean/simple modeling, and certainly works well for that.
Sounds great!
Can we have all the videos this week please? I’m eager to restart my car now!
Ha! Some basic renders this week, videos take a lot of time to make.
