There seems to be a problem in V7 where imported OBJ file with the corresponding mtl (material info file) don’t work properly and the texture is not assigned (works fine in V6 and before).
Right now a file with a diffuse map JPG after importing gets the file name of the mtl file put into the diffuse map material slot instead of the actual JPG file path listed in the mtl file.
Hi @pascal - I uploaded a sample file via support site as a sample. Wondering if anyone else is having similar problem.
thanks,
–jarek
