Hello - First, a big ‘thank you’ to all on the development team and all other testers. Rhino made a HUGE leap forward with v5, and it is my hope that it continues to WOW in V6. Rhino is hands down the most versatile design tool in my opinion.
I use Rhino primarily to align and transform digitized data to logical XYZ space and sometimes create additional geometry to boolean - then export it (but quite often the boolean operations fail…I think it needs looser tolerance for artistic/organic shape-type work).
I typically work with STL meshes and set my viewports to ‘rendered’ in order to see the mesh ‘skinned’ - because all other viewport settings make seeing the mesh edges difficult or impossible to see. This works well in R5, but doing the same settings in R6, the grid is gone. If I need to precisely rotate something to align it to XYZ (for CNC work let’s say) - I have to be able to see the mesh, and grid, plus snap to the grid.
The render itself looks fantastic(!)…BUT, why can’t I toggle on the grid? I’ve tried using the command, but no change took place.
I have also opened an existing R5 collection of meshes in R6, and only a few of the meshes displayed in anything but Wireframe or Shaded modes. I have no idea why. Works fine in R5.
Is this a known issue?
While I am here…
I’d like to see some improvements to the 2D/vector drawing tools for artistic type work. The drawing tools are quite cumbersome and unintuitive in this area. Specifically, the polyline tool (or something like it). Quite often I find myself popping out of Rhino and importing work done in another program. It would be nice to have a mix of lines, bezier & arcs along a polyline that could be selected/changed on the fly via shortcut keys when editing at the node level. It is extremely tedious to draw freeform 2D in Rhino (E.G. - digitizing a photo with minimal nodes, using a combination of square corners and bezier curves in between), because you have to keep popping out of the tool to change from lines to curves etc.
I would also like to see some improvements with mesh boolean operations, including split/trim. As you may already know, R5 will often run the command and the finished product is no different than the original meshes selected for the boolean operation. Engineering applications probably want a super-high level of precision here. Artists - not so much.
Thanks!
