Chita
(Dusan)
April 26, 2018, 5:58pm
1
when i use smart track ( i have long delay a activate point with “ctrl”) :
Situation - i have two lines - parallelly and i woul like to snap between two smart points on line - see screen 1. But the smart “mid” snap is unfunctional (V5 work great).
When i start line “in air” and define two smart poits then the “mid” snap is OK - see screen 2.
1
2
pascal
(Pascal Golay)
April 26, 2018, 6:59pm
2
Hello - so far this seems to work correctly here.
Try by turning on the “Planar” option.
Chita
(Dusan)
April 26, 2018, 8:24pm
4
“Try by turning on the “Planar” option.” - not working
New knowledge - this fail is only if i begin draw line from another point (from end of curve). If i begin draw “in air” then works corretly.
pascal
(Pascal Golay)
April 26, 2018, 8:33pm
5
Hello - I’ve been messing with this some more and right now it seems to me to be equally unpredictable in both V5 and V6…
Chita
(Dusan)
April 27, 2018, 6:05am
6
I don´t think it…Here is V5 gif. By me worked v5 always well…
Try double ctrl to clear the smart points before creating the new 2 points for the mid.
it worked for me.
it seems that it doesn’t work when you have more than 2 smart points
pascal
(Pascal Golay)
May 2, 2018, 9:07pm
8
Yeah, I do see a difference when the line starts in space. It does not seem 100% repeatable here but I do see it.
https://mcneel.myjetbrains.com/youtrack/issue/RH-45833
Chita
(Dusan)
May 3, 2018, 1:32pm
9
Hi daniel_acg - Yes, than you, it works! But it is different procedure than in V5.
Chita
(Dusan)
May 3, 2018, 1:34pm
10
Hello Pascal, thank you for testing and “registration”
