With Rhino-6 (Beta), I use groups to select objects with X,Y and Z movements. Is there a possibility to see existing groupnames while using setgroupname?
Hi @Frits1956, no. But you might try the _SelGroup command to get a selectable list of all group names.
_
c.
Hi Clement, I know but then I see only the named “visible” groups. When accidentally used the same name, the objects are added to the previous group…
