V5 to V6 annotation compatibility
Hi Brian,
It looks like I have some work to do.
[quote=“BrianM, post:11, topic:42660”]
Here are some of the 1000 words anyway, for a background into the importance of V5/V6 annotation compatibility. There is a 100% certainty that some jobs (in my case) will traverse the V5/V6 transition period and Saving back to V5 will definitely be happening for work sharing until everyone converts to V6
[/quote] Impressive. Thank you for the image.
The screenshot in the previous post is the modelspace of a file with 10 layouts with details of varying scales. I do all my 2D drawing in modelspace and use layouts for titles only, except for the odd diagram type drawing where it’s useful to annotate in Layout and have a model in the detail, for example
[/quote] Very common approach for our Rhino 5 customers, especially those who are taking the models to and from, AutoCAD and Rhino.
This particular job consisted of a master model, a set of 54 drawings, bursting with dims and text spread over 8 files. Smaller jobs would be contained within one file, I find there is a saturation point if a file is loaded up with too much linework, panning and zooming around the modelspace becomes hesitant,
[/quote] Is this any better in Rhino 6? You likely can not answer this question yet. Hopefully this week or next with the new WIP gets posted, you will be able to use Layouts and test this for us. There have been extensive display improvements. I really want to know if this is better. If not, I would like to get a file from you the show the issue.
so I generally split the files up and position the work across all the files so that copying, pasting and worksession is always correctly aligned and not overlapping or miles away.
[/quote] So a Worksession attachment works better than linked blocks here? I would like to understand this choice better.
The above job involved working with colleages who worked in Acad, all these files were passed back and forth without major issue. Some minor issues arose with dim and leader alignment - i.e. dims are re-centred when opened in Acad -
[/quote] This sounds like a bug. I will get it posted. (1)
When a file comes back to Rhino from dwg, the layer hierarchy is lost in Acad, resulting in a big layer mess, there are ways to sort that out -
[/quote] Do you save Rhino layer states and then restore to that state when you re-import or reopen the AutoCAD DWG?.
A tip for checking what has been edited is to worksession the edited file over the original and select the worksession - anything not yellow has changed basically.
[/quote] Visual examination! Thanks for the recommendation.
Another quirk with 2d linework is the way Rhino converts simple arc/line geometry into a nurbs curve if you happen to nudge a grip.
[/quote] This sounds like a bug. I will get it posted and see if we can make this better. (2)
For example a rectangle with radiused corners - try picking an endpoint after a stretch, anyway this goes into Acad as a spline if you forget to simplify it, causing a few raised eyebrows
[/quote] This sounds like a bug. I will get it posted. (3)
I will let you know the tracker numbers when I get them posted.
And I will also let you know if I have questions when I am writing these up.
Thanks again for the details, Brian.
Sincerely,
Mary Ann Fugier
