Hi there,
My computer was rendering things well beofre, but today I there was a random pop up window I don’t remember the information. After I accidently click it. Somehow the render in my computer is not working, keep telling me the bitmap isn’t loading, eventhough the materials are all stored in the file and there’s no missing material. It would be a great help if this question can be solved, it’s almost final but I can’t do anything about it now… :((
Hope my first question form arn’t too fonsuing. Great appreciation in advance!
Here’s the error code hope can help:
| 2023/11/23 上午7:58:10 | Info | [V-Ray] Loading plugins from C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayappsdk\bin/plugins\vray_*.dll |
| 2023/11/23 上午7:58:10 | Info | [V-Ray] 79 plugin(s) loaded successfully |
| 2023/11/23 上午7:58:10 | Info | [V-Ray] Finished loading plugins. |
| 2023/11/23 上午7:58:11 | Info | [V-Ray] Setting number of rendering threads to 31. |
| 2023/11/23 上午7:58:11 | Info | [V-Ray] GI engines: ‘Brute force’ and ‘Light cache’ |
| 2023/11/23 上午7:58:11 | Warning | [V-Ray] Max sample level set to 0 - rendering could take longer than expected. Consider setting a value to decrease the render time (i.e. 10000). |
| 2023/11/23 上午7:58:11 | Info | [V-Ray] Progressive RPP must be disabled when Adaptive Lights are used. Disabling progressive RPP |
| 2023/11/23 上午7:58:11 | Info | [V-Ray] Preparing renderer… |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] Using per-pixel filtering for IPR. |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] Creating bitmap manager |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] Bitmap manager created. |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] Light tree is enabled with clamp coefficient 0.1 and even split coefficient 1. |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] CUDA renderer requested. |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] 1 plugin(s) loaded successfully |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] CUDA renderer plugin successfully loaded from C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\vrayappsdk\bin\rt_cuda.dll |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] CUDA renderer plugin instance successfully created. |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] EXT_RTOPENCL interface obtained successfully from CUDA renderer plugin instance. |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] Using lowest thread priority. |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] Max ray intensity is enabled: rendered result may have incorrect brightness. |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] Registered 1 internal light select elements. |
| 2023/11/23 上午7:58:12 | Info | [V-Ray] Disabling info and debug messages for IPR. |
| 2023/11/23 上午7:58:12 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\5068b742_OP_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\81713123_Nrm_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\81713123_Gloss_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\81713123_Diff_4k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\81713123_Refl_4k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\9e0b3748_Nrm_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\9e0b3748_Refl_1k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\9e0b3748_Diff_Mask_1k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\46b381ac_Nrm_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\46b381ac_Diff_4k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\46b381ac_Refl_4k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\46b381ac_Gloss_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\e6ce384f_Refl_3k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\29eb5895_Nrm_3k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\e6ce384f_Nrm_3k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\e6ce384f_Diff_3k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\29eb5895_Diff_3k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\b525e89f_Refl_4k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\b525e89f_Nrm_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\289faa4f_Nrm_3k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\289faa4f_Diff_3k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\773ad3da_Rough_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\773ad3da_Nrm_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\b525e89f_Diff_4k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\5068b742_Nrm_4k_raw.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Bitmap file D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\773ad3da_Refl_4k_srgb.tx failed to load: error in file format:3: ϵͳ�Ҳ���ָ����·���� |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\81713123_Gloss_4k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\81713123_Nrm_4k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\81713123_Diff_4k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\9e0b3748_Refl_1k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\81713123_Refl_4k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\46b381ac_Diff_4k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\9e0b3748_Diff_Mask_1k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\29eb5895_Nrm_3k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\46b381ac_Refl_4k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\b525e89f_Nrm_4k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\289faa4f_Nrm_3k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\46b381ac_Nrm_4k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\e6ce384f_Refl_3k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\e6ce384f_Nrm_3k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\b525e89f_Diff_4k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\773ad3da_Rough_4k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\9e0b3748_Nrm_4k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\e6ce384f_Diff_3k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\773ad3da_Refl_4k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\289faa4f_Diff_3k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\773ad3da_Nrm_4k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\5068b742_Nrm_4k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\29eb5895_Diff_3k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\b525e89f_Refl_4k_srgb.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\46b381ac_Gloss_4k_raw.tx |
| 2023/11/23 上午7:58:17 | Warning | [V-Ray] Failed to load bitmap D:\2023秋\Studio 3\FINAL RENDERS\FINAL RENDER materials\FINAL RENDER materials\FINAL RENDER materials\maps\5068b742_OP_4k_raw.tx |
