V/G Overrides Imported dwg file's line weight
Hi all,
I have import quite a few detail drawings (CAD format) .
when imported into Revit, there is no line weight. Now I just need to choose the structure workset/layer to override the line weight to 8( as shown below).
But I found that I have to go into each other dwg file to do the some thing again and again.
If I have 100 drawings I have to do it 100 times.
Seem like filter in Revit cannot work on the imported CAD’s workset.
I wonder if there is any way in RIR can help to do this tedious job for me?
Many thanks for the help.
I would be remiss not to say that importing dwg is not recommended, for this scenario along with other known issues that it can create.
It’s understandable that for whatever reason it was unavoidable and you want to control the lineweights.
Changing the Category lineweight doesn’t do anything.
Modifying the SubCategory (object style) will.
