While doing my work my draft lineweights for my section are perfectly fine, the next second I check, theyre really thick. i cant undo it, sometimes they go back to normal sometimes they dont, its getting really frustrating, any advice?
Let’s start with some details about the problem and about your setup.
Please post a small example 3dm file.
- What specific steps do you run to trigger the issue?
- Does this happen in all files for just the one?
Please run the Rhin SystemInfo command a post the results with your file and replies to the questions.
Hopefully something obvious will stick out and suggest a change.
Thanks
