Hi There
I was wondering if anyone may know the answer to my issue, I’ve made a display mode similar to Sketchups to us for the drafting in rhino, the line weight I have are good when in the program but when it comes to printing the line weights change, even if in the printer options I have altered the lineweight there or played around with ’ match viewport display’ and 'match pattern definition.
Yes both are correct! How did you manage this? was it in the prit settings from a rhino pdf or something else? Thanks so much again been test printing it for days with the thickest lines coming out!
Primary display and OpenGL: NVIDIA GeForce RTX 2070 with Max-Q Design (NVidia) Memory: 8GB, Driver date: 4-8-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.31
Secondary graphics devices.
Intel(R) UHD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
- There are no monitors attached to this device. Laptop lid is probably closed
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 4-8-2021
Driver Version: 27.21.14.6231
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
It works perfectly fine on the display and viewing, the issue is actually when exporting it to a pdf, the line weight gets super thick and haven’t been able to fix it, I’ve played around with the Lineweight settings on the print setting but it hasn’t solved the issue.
Ah thanks, its just to do a mode where it looks like a line drawing instead of having to do make 2d and then find a way of incorporating shadows into it so you just get it all at once.
I Love this video, been spending too much time looking at them! yeah its more about how to use rhino and reduce the workflow of having to make the process better so instead of make 2d just have the 3d model there.
This image depicts genuine Rhinoceros 3D lines to cover the existing ARCHITECT’s (and designers) mode. PrintDisplay = ON
I then print the document as a PDF. After that, what do you anticipate? I’m referring to the result of the print and your following action. For example, importing the PDF into AI?
I’m trying to come up with a solution we can all share.
I’ve updated all the drivers and had the same issue, ive even tried on another computer and had the same issue, how did you manage to get the results that you did?
Im trying to figure it out more from the layout tab, so when im on the layout tab this is the line weight i have, but when printing through this way the line weights just get so thick. Viewing in rhino is fine but it is just getting it out into a drawing for construction.
