UV Unwrap paper cut
Hi McNeel
When you run UnWrap from the button in the Texture Mapping tab, the command prompt expects you to confirm (or change) the mapping channel, but as you activate the command, the prompt doesn’t take focus. If I press Enter to confirm mapping channel 1, it just repeats the Unwrap command. Instead you have to move the cursor to the prompt and click (or click in one one of the viewports to activate it). It would be nice if this could be tuned up :slight_smile:
TIA, Jakob
Hi @Normand ,
Thanks for the report, this is on the pile already as https://mcneel.myjetbrains.com/youtrack/issue/RH-74514 and slated to fix for 8.0.
