Using Rhino's squish command in Grasshopper
I am trying to use the Rhino squish command in grasshopper. I have a python block that can run the command, but it requires baking to be part of the process. I am wondering if there is a way to use grasshopper meshes instead of ID’s selected from Rhino?
Screenshot 2024-06-27 114059
Squish issue.gh (9.5 KB)
You could try forcing this ‘physically’ with kangaroo - easier when you have a simple naked edge like in your case.
Triangulate your mesh and then unfold. This helps if you’re not after 100% exactness, which I think you weren’t anyway because squish doesn’t do that.
Check attached file:
Squish issue.gh (21.0 KB)
There’s also a simpler ‘fake squish’ for this case in the file, if you wish to stick with nurbs:
NOTE:
Make sure you press that reset button:
Oh wow! thank you that is all very helpful! I was looking to see if I could find a way to do this with python, as I am also trying to be able to un-squish curves to add onto the original surface.
Squish issue.gh (13.6 KB)
To use the Rhino squish command in Grasshopper with Python, you can employ the Squisher from RhinoCommon.
import Rhino.Geometry as rg
squisher = rg.Squisher()
parameter = rg.SquishParameters.Default
a = squisher.SquishSurface(parameter, srf)
Squish.gh (8.4 KB)
Not sure what this was, no curves were in the file, maybe internalize them?
Equally unsure what your end goal or workflow is, not that I need to know, though :slight_smile:
Mahdiyar corrected the python - not sure it’ll work with your halved sphere automatically, though.
I tweaked* the previous file:
Squish issue.gh (37.9 KB)
*made trimesh border vertices use ‘co-circular’ goal, played with MeshMap and some surface morphing options to ‘unsquish’ some test curves - unsure that’s what you’re doing, though:
Cheers!
Thank you! This was exactly what I was trying to do. I ended up figuring out how to use this to un-squish curves as well.
Squished.gh (16.1 KB)
Is it possible to squich points/curves with the surface ?
I am getting some errors simply providing points to sqich wit the points:
Please how to convert points to the proper format so the squicher sqiches ? :smiley:
I’m not 100% sure if I understand what you are asking correctly, so I apologize if I am misunderstanding. But I would try setting either the mesh or points inputs to list access?
Yes you are right, that was the main problem.
Thank you.
