Hello, everyone,
The following is the way I tried, using rhino instructions smash / squish to flatten the surface and draw the curve for projection, but the result is distorted. I want to ask what is wrong with this idea?surface.gh (253.7 KB)
The first option works well if you run the “ShrinkTrimmedSrf” command on the 3D surface:
The second option is more distorted, but I was able to get it oriented correctly using the “Dir” command and reversing the V.
Thank you so much ![]()
There was a very interesting discussion a while back on here along the same lines. You might be interested to take a look. See link below.
