What I want to do is really simple, I here have this curtain wall, divided only in the vertical direction, let’s say the base curve is 12100 mm, and my optimum panel length in the U direction is 2500 mm, I want to create a much 2500 mm divisions as possible but make the last 2 panels equal, meaning I’d get 3 * 2500 mm panels and the last two panels would be equal at 2300 mm.
I tried to create it in Revit but the last part of creating two equal panels at the end seems impossible to automate for a large number of these walls in Revit through the type parameters, so I thought I may create the division lines in using grasshopper and create curtain grids out of them in Revit, but I don’t believe rhino inside has this feature of curtianing curtain grids yet, so any ideas how I can create this?
Hey @208ramyy98 ,
You can go through the below topic, should contain what you are looking for…
Hey @Japhy, I am trying to do this my self and your last file upload is out of date. Is there an updated version for this node?
