How to draw curtain walls using "rhininside" and add curtain grids using lines?
What I’m trying to do is draw up a curtain wall using lines in “Rhino.”
But, I can’t find a way to add curtain grids to the curtain wall among the “Rhinoinside” parts.
Please let me know if I can solve this problem with another method or Api.
Thank you:>
This will have to suffice until a component is added.
Hello, C#, I looked up Python code, but I couldn’t find an answer because I didn’t know much about programming.
If you don’t mind, may I ask you for the code for the initial setting of c# or Python code at Grasshopper?
i’m not exactly sure what you are asking. The code for the component is in the zip file on the link i provided. You double click the python icon on the component to open the code editor.
If you are referring to setting up basic coding of RiR you can refer to the guides.
There’s some information I haven’t seen before. Thank you for your answer!
How should I divide the ground into grids? I want to pave the ground and be able to record the dimensions and quantity of each type of brick.
