Hello Gyus.
when i tried to load the Rhino 4 plugin in Rhino 5 32 bit. At the first load it runs OK but when i closes rhino 5 and restarts it it gives me an Errors.
pls check the attached image.
Hello Gyus.
Which plug in?
Plugin i created using VB.net.
I just found that it gives an error when i add the reference for Rhino 4 script library.
and uses this code
Public Class UserControl1
Public obj As Object = RhUtil.RhinoApp.GetRhinoScriptInterface()
Public RScript As RhinoScript4.IRhinoScript = CType(obj, RhinoScript4.IRhinoScript)
Public Sub New()
' This call is required by the Windows Form Designer.
InitializeComponent()
End Sub
Public Shared Function BarID() As Guid
Dim g As New Guid("{45A2D5CD-CC07-4ab6-8C74-00ED4F416924}")
Return g
End Function
Private Sub UserControl1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
End Sub
End Class
When i use any Rscript. command in UserControl1_Load it gives an Error.
Like If I use under button click event, it works fine
Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
Dim arrPlane = RScript.WorldXYPlane
RScript.AddCircle(arrPlane, 5.0)
End Sub
But If i use under plugin_Load event is gives those Errors
End Sub
Resolved.
I was using the Script object under load event. that was giving me an error in Rhino 5.0.
So i shifted that code so it will run after loading event.
Thank you guys for your replies.
