Using Modules unavailable in Rhino8 Python editor
Hi All,
May I ask how do you import a module that’s currently unavailable?
Is it possible to do pip install in Rhino Python Editor?
The module I would like to use is Tkinter
You can use # r: modulename after the line with #! python3 to install other modules.
tkinter should work on at least Windows. For Mac there is this YT item: RH-67505 Implement support for tkinter, turtle on macOS
A topic from earlier this year: Loading Tkinter in Python for Rhino 8 - #2 by scottd
Hi Nathan,
Thank you so much for the fast response!
May I ask you to clarify if the following script looks correct to you?
I am still getting the"" Message: No module named tkinter""
Does it have anything to do with my Python setting?
#! python3
# r: tkinter
import scriptcontext as sc
import math
import System
import System.Collections.Generic
import Rhino
import tkinter
tkinter._test()
Some other information:
print(sys.version)
returns [.NETCoreApp,Version=v3.1 on .NET 7.0.20 (64-bit)]
I guess this means it is running ironpython
Is there a way for me a explicitly enable Cpython on my machine?
I have Rhino8 SR13
Make sure you are using _ScriptEditor to start the script editor, and that you select python 3 when adding a new script.
amazing. everything works! thanks again
