Hey there,
I am working on a project, where we often need to use a complex algorithm, which we have designed in Grashopper. The algorithm works perfectly, if it is used in the right environment. However, it needs to run in that exact same setup (e.g. Rhino 5, right plug-ins and dependencies installed).
We can share the file, but it doesn’t really work if the other person has to rebuild the complete environment. From programming I know, that there is a way to work with a ‘Containerization’, where such an environment can be shared in a team. Maybe you could also create an environment and load it into a virtual machine?
Has anyone made any experiences with that topic or can give me a tip on where to start?
Thank you!
David
Has anyone m
