User Text with Content Cache
Hi. I’m struggling to figure out how to use the Rhino 8 GH User Text Node with Model Object and Content Cashe. My goal is to ingest geometry with user text attributes from Rhino into GH. Do some modification to the geometry with GH. Then ‘bake’ back to Rhino the modified geometry WITH the user text attributes preserved. I’ve tried in vain to figure out how to make this work and the screenshot below appears to work but when you push the geometry doesn’t have the user text attributes included. Can anyone enlighten me as to what I’m missing?
usertextQuestion.3dm (206.0 KB)
usertextQuestion.gh (26.7 KB)
I don’t understand what you’re saying shouldn’t work. The only thing I see is that your Rhino 8 installation is from August and maybe you need to update…
Hi Martin, thanks for taking a look. So your saying based on the shared file and the screen shot the expected behavior is the geometry should get pushed to Rhino with user text attributes and colors. Apologies I miss spoke in my original post. The user text is coming through correctly its the color on the meshes that isn’t getting pushed.
Thanks
I tried a different way of putting the script together but still can’t get it to bake the color and the user text data. I can get either the color or the text data but never both…
usertextQuestion2.gh (17.2 KB)
I think this has to do with a conflict between the mesh color object which is a Grasshopper geometry and the Model Object Mesh that originally came into the definition.
We need to make a simpler definition that shows the problem.
The userdata belongs on the model object geometry. But the geometry being input is a Mesh color object. In this case it is not clear which object wins when placed in the Model Object component.
To make this more clear wouldn’t a UserText input be needed on the Model Object component? Becuase right now the Geometry and the Usertext are intertwined.
Here is a start to a simpler cnavas that we maight be able to play with:
usertextQuestionsimple.gh (9.5 KB)
usertextQuestionsimple.3dm (3.4 MB)
addUserTxt.3dm (3.3 MB)
addUserTxt_02.gh (13.2 KB)
old version with custom usertext key - value list juggling:
addUserTxt.gh (15.5 KB)
my approach would be:
  • to use the initial object and change / multiply the geomety (keep / multiply all attributes and within the attributes keep the usertext)
  • get the user Text
  • add new items at the end of the list for key / value (just adding the former face index)
  • set the updated User text
  • bake it with new user text.
EDIT:
the merge option of user Text will do the list inserting:
so it s even simpler:
The user text we see in properties belongs to the attributes, its “attributes user Text / Data”
This can also seen with _what command in rhino.
does this help ?
kind regards - tom
Hi @frederick.michael,
What version of Rhino are you using?
Something similar was fixed on 8.25.
His Rhino is from August…
Yes, I expect the update will fix it.
