I’d like to ask about the contents of a .usda file exported from Rhino 9.
Version: Rhino 9 BETA (9.0.26293.12303, 2026/10/20)
■ Steps to reproduce
- Object: Mesh (6 faces), X=1000, Y=2000, Z=3000 (mm), with one corner at the origin
- Material: Physically Based, base color R=G=B=118
- Export options:
- Prim Settings
- Default layer: Default
- Model name: Cube
- References
- Block handling: Embedded
- Data
- Include user strings: checked
- Prim Settings
The exported Cube.usda is attached.
■ Question 1: Option to export as Z-up
The exported file has upAxis = “Y”.
From extent = [(0, 0, -2000), (1000, 3000, 0)], I confirmed that Rhino coordinates (x, y, z) are converted to (x, z, -y) and consistently written as Y-up.
Since USD also supports upAxis = “Z”, is there an option to export Rhino’s Z-up coordinates as-is with upAxis = “Z”?
If not, I would appreciate it if you could consider adding one.
■ Question 2: Spelling of emissiveColor
The shader input is written as inputs:emmisiveColor.
According to the UsdPreviewSurface specification, the correct name is inputs:emissiveColor,
so I suspect other applications will not read the emissive color.
Is this a typo?
Thank you for looking into this.
Cube.usda (2.7 KB)
