Hello All,
I am experimenting with the .usdz exporter in Rhino 8. Is there a way to export the usdz file with materials? I have tried exporting the polysurface geometry as usdz, as well as converting the geometry to a mesh with the “pack textures” before exporting. Both times the result as viewed from ios Quick Look on iPad is a pink striped pattern. Is there any way to fix this?
Thanks
The materials should be in the usdz file.
The problem is likely with the viewer.
To confirm, if you export as usda you should see the material files on you disk next the the exported file.
Could you provide the 3dm file?
Hi Aain
I have the same issue exported USD files are textuerless.
Hi Charles -
Please respond to this:
Hi Alain,
Thank you for your reply. Interestingly, I’ve only encountered this issue 2 or 3 times, and it seemed to resolve itself.
However, I’ve noticed a random bug with the UNDO command. Occasionally, it stops working and instead repeats the most recent command I executed. The only way to fix this is by shutting down and restarting Rhino. This issue has been occurring intermittently over the past 2 to 3 months.
My Version 8 SR12
(8.12.24282.7001, 2024-10-08)
Thank you.
Hi Charles -
Please start new threads for different issues!
When you run into this undo issue again, please use AuditUndo and TestCurrentUndo and provide the information from those command in this following thread:
Hi Alain
The USD texture problem is back.
I am sharing with you both files.
Thank You
(attachments)
USD test.usdz (3.03 MB)
USD test.3dm (1.86 MB)
Hi Charles,
Which app are you using to open the USD file?
Hi Alain
I am using Keyshot.
BTW is it possible to add ambient occlusion to the usd export?
Thank you
Hi Nathan
Thank you for your help.
I have been been opening it in Keyshot.
Regards
Hi Charles,
Could you export a USDZ file from Keyshot that has some textures so we can compare?
Ambient occlusion request logged here.
Restarting Rhino cleares the USDZ export glitches because the application caches mesh normals, UV mappings, and texture bakes in memory, which can corrupt during iterative imports/exports-especially with imported meshes carrying external format artifacts. Just restart Rhino before final export, and it will work normaly!
