Exporting the same objects from Rhino 8 and 9 WIP lead to different files.
Rhino 8 exports the material, Rhino 9 WIP doesn’t.
I don’t know if it’s ever been different in Rhino 9 WIP but can this please be fixed?
As a little extra, export of nested blocks would be a nice addition…
pipes-block-8.usdz (10.0 KB)
pipes-block-9.usdz (8.7 KB)
Rhino 8 export:
PK
H‰žY¬ƒ÷C=' =' pipes-block.usda† #usda 1.0
doc = """Generated from Composed Stage of root layer
metersPerUnit = 0.001
upAxis = "Y"
def Xform "Rhino"
def Xform "Geometry"
def Xform "pipes"
def Mesh "mesh0" (
apiSchemas = ["MaterialBindingAPI"]
float3[] extent = [(308.61652, 50.74137, -89.60138), (386.3836, 92.03714, -3.8519402)]
int[] faceVertexCounts = [3, 3, 3, 3, 4, 4, 4, 4, 3, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 3, 3, 3, 3, 3, 3, 3, 3, 4, 4, 4, 4, 3, 3, 3, 3]
int[] faceVertexIndices = [13, 12, 17, 13, 9, 12, 13, 14, 9, 13, 17, 14, 17, 12, 21, 26, 12, 9, 18, 21, 9, 14, 23, 18, 14, 17, 26, 23, 26, 21, 22, 21, 18, 22, 18, 23, 22, 23, 26, 22, 13, 11, 16, 13, 10, 11, 13, 15, 10, 13, 16, 15, 16, 11, 2, 8, 11, 10, 0, 2, 10, 15, 6, 0, 15, 16, 8, 6, 8, 2, 4, 2, 0, 4, 0, 6, 4, 6, 8, 4, 4, 3, 1, 4, 7, 3, 4, 5, 7, 4, 1, 5, 1, 3, 20, 19, 3, 7, 25, 20, 7, 5, 24, 25, 5, 1, 19, 24, 19, 20, 22, 20, 25, 22, 25, 24, 22, 24, 19, 22]
rel material:binding = </Rhino/Materials/material_198_255_255__7DF18FCC_4F7C_4713_EEAA8>
normal3f[] normals = [(0.93420607, 0.31646845, 0.1646414), (0.97536004, -0.14514373, -0.16615066), (0.6598589, -0.21575162, 0.7197482), (0.81423086, 0.42158163, 0.39912027), (0.8401149, 0.4716017, 0.26795298), (0.60556734, 0.31354168, -0.73142314), (0.357413, 0.84868765, 0.38985285), (0.44443688, 0.8802667, -0.16615148), (0.08306592, 0.31646794, 0.9449593), (0.71388334, 0.014880735, -0.70010656), (-0.083066955, -0.31646603, -0.9449599), (-0.35741344, -0.8486881, -0.38985142), (0.14769709, -0.5623762, -0.8135838), (-0.2523699, -0.20977598, -0.94461817), (0.14393845, 0.5921364, -0.79287845), (-0.65985924, 0.21575595, -0.7197466), (-0.934207, -0.31646612, -0.16464046), (-0.4222475, 0.014880887, -0.9063584), (0.42224774, -0.014879324, 0.90635836), (-0.44443977, -0.8802651, 0.16615242), (-0.6055681, -0.31354198, 0.73142236), (-0.14393842, -0.5921334, 0.79288065), (-0.6346104, -0.28362316, 0.7189072), (-0.14769678, 0.5623753, 0.81358445), (-0.8142317, -0.4215819, -0.39911833), (-0.9753604, 0.14514062, 0.16615158), (-0.7138831, -0.014879179, 0.7001068)]
point3f[] points = [(386.3836, 91.11531, -23.305374), (386.10626, 90.22728, -22.6296), (385.90842, 90.19348, -22.343903), (385.82718, 91.20888, -21.650524), (385.64648, 91.11531, -22.6296), (385.46576, 91.02174, -23.608677), (385.38455, 92.03714, -22.915298), (385.1867, 92.003334, -22.6296), (384.90936, 91.11531, -21.953825), (325.85077, 53.29893, -88.74699), (325.60397, 53.29893, -89.60138), (325.12878, 52.3771, -88.63991), (324.87012, 52.2991, -88.943535), (324.86685, 53.29893, -88.925606), (324.86362, 54.298767, -88.90767), (324.60492, 54.220764, -89.211296), (324.12976, 53.29893, -88.249825), (323.88293, 53.29893, -89.104225), (310.58438, 51.741203, -4.652397), (310.06024, 50.853176, -4.8310165), (309.78116, 51.83477, -3.8519402), (309.6037, 50.74137, -4.848946), (309.60046, 51.741203, -4.8310165), (309.5972, 52.74104, -4.813087), (309.41974, 51.64764, -5.8100924), (309.14066, 52.62923, -4.8310165), (308.61652, 51.741203, -5.0096354)]
def Mesh "mesh1" (
float3[] extent = [(158.61653, 50.74137, -89.60138), (236.38359, 92.03714, -3.8519402)]
point3f[] points = [(236.38359, 91.11531, -23.305374), (236.10626, 90.22728, -22.6296), (235.90842, 90.19348, -22.343903), (235.82718, 91.20888, -21.650524), (235.64648, 91.11531, -22.6296), (235.46577, 91.02174, -23.608677), (235.38455, 92.03714, -22.915298), (235.18669, 92.003334, -22.6296), (234.90936, 91.11531, -21.953825), (175.85077, 53.29893, -88.74699), (175.60397, 53.29893, -89.60138), (175.12878, 52.3771, -88.63991), (174.87012, 52.2991, -88.943535), (174.86685, 53.29893, -88.925606), (174.8636, 54.298767, -88.90767), (174.60493, 54.220764, -89.211296), (174.12975, 53.29893, -88.249825), (173.88293, 53.29893, -89.104225), (160.58437, 51.741203, -4.652397), (160.06024, 50.853176, -4.8310165), (159.78116, 51.83477, -3.8519402), (159.6037, 50.74137, -4.848946), (159.60045, 51.741203, -4.8310165), (159.5972, 52.74104, -4.813087), (159.41974, 51.64764, -5.8100924), (159.14066, 52.62923, -4.8310165), (158.61653, 51.741203, -5.0096354)]
def Mesh "mesh2" (
float3[] extent = [(8.616531, 50.74137, -89.60138), (86.38359, 92.03714, -3.8519402)]
point3f[] points = [(86.38359, 91.11531, -23.305374), (86.10627, 90.22728, -22.6296), (85.90841, 90.19348, -22.343903), (85.82719, 91.20888, -21.650524), (85.646484, 91.11531, -22.6296), (85.465775, 91.02174, -23.608677), (85.38456, 92.03714, -22.915298), (85.18669, 92.003334, -22.6296), (84.90937, 91.11531, -21.953825), (25.850777, 53.29893, -88.74699), (25.603966, 53.29893, -89.60138), (25.128784, 52.3771, -88.63991), (24.870113, 52.2991, -88.943535), (24.866858, 53.29893, -88.925606), (24.863604, 54.298767, -88.90767), (24.604933, 54.220764, -89.211296), (24.12975, 53.29893, -88.249825), (23.88294, 53.29893, -89.104225), (10.584368, 51.741203, -4.652397), (10.060241, 50.853176, -4.8310165), (9.7811575, 51.83477, -3.8519402), (9.603704, 50.74137, -4.848946), (9.60045, 51.741203, -4.8310165), (9.597195, 52.74104, -4.813087), (9.419742, 51.64764, -5.8100924), (9.140658, 52.62923, -4.8310165), (8.616531, 51.741203, -5.0096354)]
def "Materials"
def Material "material_198_255_255__7DF18FCC_4F7C_4713_EEAA8"
token outputs:surface.connect = </Rhino/Materials/material_198_255_255__7DF18FCC_4F7C_4713_EEAA8/shader0.outputs:surface>
def Shader "shader0"
uniform token info:id = "UsdPreviewSurface"
float inputs:clearcoat = 0
color3f inputs:diffuseColor = (0.7764706, 1, 1)
color3f inputs:emmisiveColor = (0, 0, 0)
float inputs:ior = 1.52
float inputs:metallic = 0
float inputs:opacity = 1
float inputs:roughness = 1
int inputs:useSpecularWorkflow = 0
PK
H‰žY¬ƒ÷C=' =' pipes-block.usda† PK P }'
Rhino 9 export:
PK
T‡žY0%Q)" " pipes-block.usda† #usda 1.0
upAxis = "Y"
def Xform "Rhino"
def Xform "pipes"
def Mesh "mesh0"
def Mesh "mesh1"
def Mesh "mesh2"
PK
T‡žY0%Q)" " pipes-block.usda† PK P X"
