Hey Guys,
first I want to say thanks for the Layout function in MacRhino. I think is a very good matter for fast and professional outputs and at last I can make a beautiful technical drawing paper without the help of Illustrator. Seems to be a big step for all MacRhino users
I tested the new layout function a little bit and now I have some usability wishes
I need a log time to found the command to scale a Viewport exactly. On technical papers sometimes have to use a specific scale like 1:100 as a sample. I think the command is to deep in the menue (View->Layout->Scale Detail View). My wish is this function in a command that I can type via keyboard or a good visible dialogue in the layout screen (like a property screen for the viewports).
Is there a possibility to lock a scale because by hitting the mouse wheel the scale change really fast-
It is possible to fit all viewports to a similar position like in a technical drawing. At the moment I have to draw temporarily construction lines to fit my drawing a the same position on the viewport.
Is there a possibility to modify the virtual paper color (not the Print paper color)? The gray is so sad
- If I want to draw something in a layout panel I can’t see what I am drawing while I am drawing. I have to finish the command / task before I see something (drawing lines, drawing dims,etc.). It looks like a little bug. It seems to be a bug out of my system - after Rhino re-start everything is normal and visible while drawing.
Is there a possibility to create more tool pallets for the layout screen or maybe a head column with the important tools for a “layout page”. Because while using it in fullscreen mode you have to move the pallets from the main window or switch much between the screens.
Is there a possibility to fill a curve with a full color hatch (a Ink button or a tool like the interactive color tool from Illustrator would be interesting)? I think with this function it will be very easy to create nice illustrations of floor product Illustrations,floor plans or something similar.
For the future: Will be a possibility to integrate Render windows in the Layout Page? With neon and cycles it could be possible to get good real time renderings in the Page. Or with Penguin there will be a possibility to find a good way between good illustration and good technical drawing without any other layout or illustration tools
more to be announced
