URGENT :( Using Kangaroo without mesh extrusion
Hello everyone!
I created a form using Kangaroo, but later I needed to extrude it after converting it to SubD to achieve the proper shape. I wonder if there is a way to accomplish this directly with Kangaroo, as I couldn’t make it work.
Thank you!
This is the form i got from Kangaroo,
And this is after extrude it -2 meter from the base geometry.
kangaroo_exp.gh (252.0 KB)
guys keep in mind this is an URGENT one
What’s wrong with what you achieve in the second picture?
Does it really all have to be generated in Kangaroo?
I mean it’s a lot of work just to end up with about the same, but way more unpredictable result that you already have.
Thank you once again,
Well, yeah as you said it can be challenging and the result may not be the one i want so im gonna go with the same way i have done!
Thank you so much for sharing your thoughts on this
