hello i have an issue to render an STEP import (i can’t apply a material or texture on the object)
OBJ. is working weel, so i tried to export the fbx into OBJ and re-import it but it is the same issue.
anyone has an idea ?
(the client has avery model in STEP so it is problematic)
thanks !
picture : the render one is the OBJ and the white one the STEP
Any
i precise that the layer color doesnt apply to the FBX, it is still white in any case…
wim
(Wim Dekeyser)
November 13, 2020, 9:41am
3
Hi -
You added the vray tag to the topic - is this a V-Ray-specific issue or is the same thing happening with the Rhino Render?
For rendering, the layer color doesn’t apply.
Can you post a small FBX file that you are having issues with?
bukacek
(Bukacek)
November 13, 2020, 10:09am
5
this STEP file contains geometry as a Block Instance and this cannot be assigned with V-Ray material
i would use _ExplodeBlock command and assign material to the polysurfaces
