Hey guys,
How would we flatten this curve (or surface) to get the best result. We’re trying to get the most accurate measurement for this surface to be able to cover it with material.
Thanks!
Hi @Castaway_CAD ,
If you split the curve at each of the four corners you can use the Length command to measure each side without needing to flatten it.
HTH
Jeremy
if you have the surface you could use, UnrollSrf, Squish, or CreateUVCrv.
