HI there, I know how to unroll surfaces, but I wonder if there is a way to unroll curves? I made a design that is in a cylinder shape and need to unroll it flat to send to the client.
Thanks in advance for your help!
Devon design.3dm (598.1 KB)
The unroll command asks you to select curves, text dots and points on the surface to unroll.
That means you can unroll a curve as long as you have a surface for that curve.
Your example seems to be circular. I moved everything to the origin and created a cylinder, then pulled your curves to my cylinder and unrolled everything.
Devon design.3dm (6.5 MB)
Ahh so simple. Thank you Martin. I appreciate it.
Thanks Courtney, please click the solution button above.
