I’m having a problem with UnrollSrf that I can’t find mentioned on this forum. I created 6 surfaces in the same revolve command, then trimmed some holes in them (also using one command). Two commands created these 6 objects. When I use the UnrollSrf command on them, I get the same command line response (“One Surface Unrolled”), however only three of the attempts actually produce a result. I’ve attached a file to take a look at with a surface that is unrolling and one that is not producing a result: Unroll objects.3dm (1.7 MB)
I’ve tinkered with my tolerances, but couldn’t get that to help. I’ve used UnrollSrf many times in the past and never had this problem. Any help would be greatly appreciated.
Thanks.
