Hi all,
I am having problems unrolling this specific surface (surface 1).
And surface 2 is not unrolling at all. I have created both surfaces using ruled surface and two interpolated splines.
Any help is appreciated, thank you
unroll brep.gh (11.1 KB)
I think you’re using this component wrong, you can’t unroll surface. Brep Unroll.
example:
Cheers,
BVR
I don’t really see any difference between what you have shown and what I have done.
I have also used the component to unroll several surfaces properly. It is simply using the Rhinocommon repository to unroll.
technostark:
Hope someone else joins this thread and gives better solution.
Sorry if that came off as rude, I didn’t mean to offend you. Just that I don’t see any difference other than the fact that you have used a brep and I have used a surface
