Unroll Brep Problems
I hope someone here can help me here:
When I unroll simple BREP geometries (for example my rectangular towers), this works without any problems. However, as soon as I want to unroll more complex shapes, difficulties arise, such as overlapping surfaces or other problems. Does anyone have any tips or advice on how best to overcome such challenges? I want to end up with a smooth unrolled surface that I can continue working with :slight_smile:
241203_Unroll Brep.gh (46.3 KB)
Hello, you need to remove the L-shaped yellow colored surfaces and unjoin the pink colored edges.
In the real world you can’t get an object like this by folding a single sheet, you will have to cut some surfaces separately and add them later.
unrollbrep.3dm (120.0 KB)
The edges that will split can be specified before unrolling:
  1. Use the UnjoinEdge command
  2. Select the edges that should be open after unrolling.
Look here:
Thanks for your response :slight_smile:
