Uninstalling and reinstalling rhino7
What is the proper way to uninstall rhino 7 and reinstall rhino 7 with grasshopper. It seems like my grasshopper has been corrupted and every time I try opening it up it crashes Rhino.
In windows the best way is to go to Add and Remove Programs and Modify>Repair the install. This is cleaner than a reinstall.
The grasshopper issue is most likely due to a bad plugin. Open Rhino and run GrasshopperLoadOnebyOne to not load plugins, if no crash then close rhino and start a process of elimination with the Grasshopper load one by one.
thank you, since I got you here I tried downloading ‘opennest’ from the plugin manager and restarted rhino and the plug in is no where to be found. would you have any idea why that is?
Is the plugin listed in your plugins?
