Hi everyone, I recently started to install opennest and something went terribly wrong. I now cannot open or run any script in grasshopper. When I try to launch grasshopper I get the attached error message followed by an immediate crash. I tried uninstalling and reinstalling rhino, closing all other programs and relaunching my computer… still none of the scripts are opening. Now, out of desperation I am updating my macOS software. Any suggestions? @DavidRutten
I’d suggest you close Rhino, then go to /Users/<YOURUSERNAME>/Library/Application Support/McNeel/Rhinoceros/7.0/Plug-ins/Grasshopper (<SERIALNUMBER>)/Libraries and delete the OpenNest related files there (if there are any).
Then, go to /Users/<YOURUSERNAME>/Library/Application Support/McNeel/Rhinoceros/packages/7.0/ and delete the OpenNest folder (if there is one).
Now, restart Rhino and Grasshopper and see if everything works.
Then, re-install OpenNest from the Rhino PackageManager. I have version 1.5.1 installed and it works fine!
I am almost certain that it had something to do with it, once I started installing OpenNest a warning window appeared asking if I trusted the download, once I agreed to continue with the install grasshopper would no longer launch.
If the PackageManager approach does not work you can use GrasshopperLoadOneByOne to load Grasshopper and skip the OpenNest plug-in. Take note of the locations and after loading Grasshopper remove the versions you have installed.
