RHINO 7 crashes when opening GRASSHOPPER
dang
When I try to open grasshopper it crashes rhino 7.
Hi Raimonch,
Close Rhino. Open a new session and then start grasshopper in the command line with grasshopperLoadOneByOne command to identify the issue.
interesting, it worked when I selected NO to each plugin… is there a way around this? appreciate your quick help.
If you select YES on the first one it fails?
You can disable the plugins from loading in the Grasshopper Preferences, or remove the problem plugin from the GH special folders directory.
