Hi!
I have a mesh where depending on parameters my normals are pointing in postive or negative Z-direction. Since Weaverbird’s Mesh Thicken doesn’t allow input of the direction, I would like to set the direction of the normals before already. That way I can control in which direction the thickening takes place. I managed to do it using C#:
private void RunScript(object MeshInput, ref object OrientedMesh)
Mesh mesh = (Mesh) MeshInput;
for(int i = 0; i < mesh.Faces.Count; i++)
var normal = mesh.Normals[0];
if(normal.Z > 0)
mesh.Flip(true, true, true);
OrientedMesh = mesh;
However, I would need to make it work without scripting, so that I do not have to wait for ShapeDiver to manually check my scripting in my model. Is there a solution with expressions and other building blocks (I am relatively new and have already tried but not succeeded)?
Cheers,
Jonathan
