I was trying to make a wall with an uneven height is it possible using grasshopper? I would be glad if you could help me with this one.
Thank you for your reply but I was hoping if it could be parametric; the one with the parametric number slider. Can you help me with that?
Is it possbile to select a point in Revit using grasshopper? I can’t find that command, I can only find select edge.
It is possible. Revit points are called as Vertex in grasshopper.
Thank you very much, I was able to do it, but I had to bake the grasshopper geometry first so I could select the points.
