Hello guys!
I don’t know why I am stuck on how to make this pattern but I can’t find an efficient way to make it. could you please help me with this?
The dimensions of the rectangles are 15x15 and 15x30
Thank you!
Hello guys!
Thank you!
Thank you HS_Kim! I can’t understand…man how can always have such an efficient solution.
However, I would really appreciate if you had a way to explain to me what shift path does in this specific case. I understand that perhaps it isn’t that easy to explain so there is no problem if you can’t. I appreciate your help anyway!
it was ask yesterday I think, it has to do with the tree structure. You could put a pramviewer and observe the effect or search the forum/google.
It surely has to do with the amount of pieces.
You should use a multiple of 3 if you want to keep the pattern you want…
