Uneven distribution with FlowAlongSrf (Act2)
Hello everyone,
I need to make very accurate flowAlong surface work, so I worked hard to get surfaces (Base and Target) structures very similar.
Iso and points are matching !.
but when flowing the results do not match.
Does anyone can help !
thanks
Fred
bad flow.3dm (226.2 KB)
Spock would say “illogical”
hi @Scherrier
What you can see is that the control points of the surfaces in V direction don’t line up.
In the attached I’ve tried to make a similar surface to the surface you are using, by reusing the inner edge of the base surface and scaling those curves up to create the profiles for a loose loften surface.
Once that surface is used to flow to, you will notice correct alignment.
good flow.3dm (459.9 KB)
Hello Gijs,
thanks for your help, yes, V don’t line up
but iso display are alined and points too. is due to weight ?
I am curious tu see what you’ve done , could you make a Rhino8 file ? please ? :sweat_smile:
@Scherrier sorry, here’s the Rhino 8 file:
good flow.3dm (407.8 KB)
