Undo does not remove the layout page
When a RhinoPageView is added using a command, and then the command is undone, the page is not removed.
Any solution?
This is true. Creating layouts in Rhino are also not undo-able.
Is there a specific reason for this behaviour?
or will this be fixed?
It hasn’t been requested before just like creating new viewports is not undoable. We try to stay focused on what our users request. Is there a reason you need this functionality?
any action should be having the same behavior i would think and wish. having undo view in another command seems reasonable but for the rest it can quickly become a flow breaker, not always do i want to proceed in the actions i started either because i changed my mind or just because it happened accidentally. having to fiddle around extra does not help to keep a flow.
I would expect all things created in a command to be removed on my undo.
Undo should basically “undo” things. not leave some parts…
It would be greatly appreciated if this is fixed.
https://mcneel.myjetbrains.com/youtrack/issue/RH-40256
Thanks @dale
