Hi im trying to split this surface into the shape of the line but whenever i split it nothing happens to the model. Could i get some feedback? thanks in advanced!
Pull the curve onto the surface first.
Upload the relevant geometry in a Rhino file.
Hello - at least some of your curves do not form closed loops:
hi, sorry im new to rhino, but what is the command to search for closed loops? thank you
Hello -try - select all the curves and Join
then, use SelOpenCrv to locate the open ones.
hi thanks for the help, managed to solved it
