Unable to load RhinoRenderCycles.rhp
Please help me with this issue. The plug-in “RhinoRenderCycles.rhp” is loading on start-up.
Once I manually try to load it from the Plug-ins folder, this is what it says: “Unable to load RhinoRenderCycles.rhp plug-in : ID already in use.”
I am unable to take renders.
Please run SystemInfo command in Rhino and post the results.
Most likely you need a CLEAN install of your nvidia driver (happening to some after windows update as of late)
Thank you for the response.
The issue seems to be solved. I found that Windows Security was blocking the plug-in from loading. The error dialogue box stated that “the author of the plug-in is unknown.” So, once I switched off “Smart App Control,” the plug-in started loading at start-up.
I am, however, posting the result of the systeminfo command below. Hope it helps.
Microsoft Windows [Version 10.0.26200.9168]
(c) Microsoft Corporation. All rights reserved.
OS Name: Microsoft Windows 11 Pro
OS Version: 10.0.26200 N/A Build 26200
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Original Install Date: 08-08-2026, 21:02:43
System Boot Time: 29-08-2026, 18:30:16
System Manufacturer: Dell Inc.
System Model: Dell Pro Precision 5 16 PW516261
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: Intel64 Family 6 Model 204 Stepping 2 GenuineIntel ~2000 Mhz
BIOS Version: Dell Inc. 1.5.2, 22-07-2026
Windows Directory: C:\windows
System Directory: C:\windows\system32
Boot Device: \Device\HarddiskVolume1
System Locale: en-us;English (United States)
Input Locale: 00004009
Time Zone: (UTC+05:30) Chennai, Kolkata, Mumbai, New Delhi
Total Physical Memory: 32,328 MB
Available Physical Memory: 18,181 MB
Virtual Memory: Max Size: 39,942 MB
Virtual Memory: Available: 19,476 MB
Virtual Memory: In Use: 20,466 MB
Page File Location(s): C:\pagefile.sys
Hotfix(s): 5 Hotfix(s) Installed.
[01]: KB5120708
[02]: KB5054156
[03]: KB5095189
[04]: KB5121003
[05]: KB5123304
Network Card(s): 3 NIC(s) Installed.
[01]: Intel(R) Wi-Fi 7 BE211 320MHz
Connection Name: Wi-Fi
DHCP Enabled: Yes
DHCP Server: 192.168.1.1
IP address(es)
[01]: 192.168.1.8
[02]: fe80::ca3d:cce8:f90f:a013
[02]: Intel(R) Ethernet Connection (25) I219-LM
Connection Name: Ethernet
Status: Media disconnected
[03]: Bluetooth Device (Personal Area Network)
Connection Name: Bluetooth Network Connection 2
Virtualization-based security: Status: Running
Required Security Properties:
Base Virtualization Support
Available Security Properties:
Secure Boot
DMA Protection
UEFI Code Readonly
SMM Security Mitigations 1.0
Mode Based Execution Control
APIC Virtualization
Services Configured:
Hypervisor enforced Code Integrity
Secure Launch
SMM Firmware Measurement
Services Running:
Secure Launch
Hypervisor-Enforced Paging Translation
App Control for Business policy: Enforced
App Control for Business user mode policy: Off
Security Features Enabled:
SMM Isolation Level: 30
Hyper-V Requirements: A hypervisor has been detected. Features required for Hyper-V will not be displayed.
Thank you
For future reference since you seem to have solved your problem, Rhino also has a builtin SystemInfo command accessible from the Rhino command line. I’m pretty sure that’s what Japhy meant.
Oops, got it. Thanx.
