Rhino 8 problem upon launching
I’m new to Rhino and I’ve just installed it to test it out (with the idea of building plugins for it in the future). Upon launching it for the first time, I get several error messages, and the command prompt reads:
System.Exception: No PlugIn subclass found. at Rhino.PlugIns.PlugIn.CreateFromAssembly(Assembly pluginAssembly, Boolean displayDebugInfo, Boolean useRhinoDotNet) Unable to load RhinoRenderCycles.rhp plug-in: initialization failed. Unable to load rdk_etoui.rhp plug-in: application initialization failed. Unable to load RhinoCycles.rhp plug-in: application initialization failed. Unable to load Displacement.rhp plug-in: Dependent DLL is out of date. Unable to load default render plug-in.
If I run _PackageManager in the command line, I get the answer: Unknown command: _PackageManager.
If I run _PlugInManager in the command line, I get the answer:
Command: _OptionsPage
Page to display ( Aliases Appearance Arctic Artistic ClippingPlanes Colors ControlPointContextMenu CursorToolTips Curves DisplayModes Files General Ghosted Grid Gumball IdleProcessor Keyboard Lights Lines Meshes ModelingAids Monochrome Mouse Nudge ObjectContextMenu Objects OpenGL OtherSettings Pen Points Raytraced Rendered SearchPaths SelectionMenu Shaded Shadows SizeAndStyles SmartTrackAndGuides SubD Surfaces Technical Toolbars UpdatesAndStatistics View ViewportContextMenu Wireframe XRay ): _PlugIns
Unknown command: _PlugIns
And if I press Enter I get the Rhino Options, but without some of the options (such as PlugIns):
I have tried uninstalling/reinstalling rhino8, and checking for updates, but the problem persists. Could someone please help me? Thank you!
Please run the Rhino command _SystemInfo and post the result in a reply.
The SystemInfo:
Rhino 8 SR21 2025-7-7 (Rhino 8, 8.21.25188.17001, Git hash:master @ 2e05bb7e11ec03aa58cc543d92330d59df05d32b)
License type: Evaluation, build 2025-07-07
License details: Cloud Zoo
Expires on: 2025-10-19
Windows 10 (10.0.10586 SR0.0) or greater (Physical RAM: 4GB)
.NET 8.0.14
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon HD 5700 Series (AMD) Memory: 1GB, Driver date: 11-4-2015 (M-D-Y). OpenGL Ver: 4.5.13399 Compatibility Profile Context 15.201.1151.1008
> Accelerated graphics device with 3 adapter port(s)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Graphics level being used: OpenGL 4.5 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.40
Driver Date: 11-4-2015
Driver Version: 15.201.1151.1008
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 8\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 8\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.21.25188.17001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.21.25188.17001
Hi RP -
On my system, that says:
Windows 10 (10.0.19045 SR0.0)
I’d make sure that Windows has all updates installed.
You are trying to run Rhino 8 on a system that is seriously inadequate. See the requirements:
Updating windows resolved the issue, thank you Win Dekeyser!
