Unable to load bongo
Hello guys i am unable to load bongo to the rhino 8 evalution software
the error it gives is the following i tried both bongo60.rhp file and bongo50.rhp file i want to try this animation that i want to do for my thesis
please help
This was solved during an email conversation and the solution was to load Bongo manually in the right order. Posting the solution here for others to find.
Here’s the instructions to load Bongo manually:
Open up Rhino and go to Tools > Options > Plug-ins.
Click the Install button and go to:
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6
Select the Bongo.20.rhp file and press Open.
Click the Install -button again and go to:
Select the BongoUI.20.v60.rhp file and press Open.
Now Bongo should be loaded inside Rhino.
Please note that the rhp files need to be loaded in that order.
If you load the UI plug-in first it will fail.
