Bongo 2 - Rhino 7 (64bit)
I just purchased Rhino 7 - educational and Bongo 2 - educational.
So, I installed both but Bongo isn’t show up. I tried re-install several times but I don’t get it.
Both 64bit.
@jeontj13
Bongo 2 should load automatically into Rhino 7 after the installation, but for some reason it doesn’t on some machines. If that’s the case the problem can be fixed by loading it manually.
Here’s the instructions to load Bongo manually:
Open up Rhino 7 and go to Tools > Options > Plug-ins.
Click the Install button and go to:
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6
Select the Bongo.20.rhp file and press Open.
Click the Install -button again and go to:
Select the BongoUI.20.v60.rhp file and press Open.
Now Bongo should be loaded inside Rhino 7.
Please note that the rhp files need to be loaded in that order.
Does that work for you?
It works for now thank you !
2021년 9월 6일 (월) 오전 4:50, Marika Almgren via McNeel Forum <mcneel@discoursemail.com>님이 작성:
Thank you Marika, worked for me!
