When I try to edit a panel when it looks like this:
It will instead wright in the Rhino command bar. However when I use the full “editor”, it works fine.
Is this a bug or have I accidently turned on something?
Hei Anders -
That’s a bug. When you restart Rhino, can you systematically reproduce that behavior? If so, please let us know the steps to do so.
Takker,
Thank you. I will try to see if I can repeat it. It went away after restarting.
Since I began using rhino 8, I have not been able to see the panel editing buttons that used to be in grasshopper. Are they turned off or is it a bug?
Hi Johan -
They are turned off.
