Hi all, thanks in advance. I am unable to read the excel file using TTToolbox. An image of the error is placed below.
Assigned Grasshopper Category! With excel sub category.
Can you share your system info? It seems that your excel cannot be read. Can you try with another file? Also can you save your file to xls instead xlsx?
Win 11, i7. Excel 2016. Using Rhino 6.
.xls also not working.
Try another file. Also run command systeminfo
Host Name: XXXXXXXXXXX
OS Name: Microsoft Windows 11 Home Single Language
OS Version: 10.0.22621 N/A Build 22621
OS Manufacturer: Microsoft Corporation
OS Configuration: Standalone Workstation
OS Build Type: Multiprocessor Free
Registered Owner: XXXXXXXXXXXXX
Registered Organization: N/A
Product ID: XXXXXXXXXXXXXXXXXXx
Original Install Date: 05-10-2022, 21:19:49
System Boot Time: 15-01-2023, 09:39:52
System Manufacturer: Dell Inc.
System Model: G3 3500
System Type: x64-based PC
Processor(s): 1 Processor(s) Installed.
[01]: Intel64 Family 6 Model 165 Stepping 2 GenuineIntel ~2592 Mhz
BIOS Version: Dell Inc. 1.20.0, 08-09-2022
Windows Directory: C:\WINDOWS
System Directory: C:\WINDOWS\system32
Boot Device: \Device\HarddiskVolume1
System Locale: en-us;English (United States)
Input Locale: 00004009
Time Zone: (UTC+05:30) Chennai, Kolkata, Mumbai, New Delhi
Total Physical Memory: 16,146 MB
Available Physical Memory: 3,662 MB
Virtual Memory: Max Size: 32,756 MB
Virtual Memory: Available: 10,439 MB
Virtual Memory: In Use: 22,317 MB
Page File Location(s): C:\pagefile.sys
Domain: WORKGROUP
Logon Server: \XXXXXXXXXXXXX
Hotfix(s): 4 Hotfix(s) Installed.
Network Card(s): 3 NIC(s) Installed.
[01]: Intel(R) Wi-Fi 6 AX201 160MHz
Connection Name: Wi-Fi
DHCP Enabled: Yes
DHCP Server:
IP address(es)
[02]: Killer E2500 Gigabit Ethernet Controller
Connection Name: Ethernet
Status: Media disconnected
[03]: Bluetooth Device (Personal Area Network)
Connection Name: Bluetooth Network Connection
Hyper-V Requirements: VM Monitor Mode Extensions: Yes
Virtualization Enabled In Firmware: Yes
Second Level Address Translation: Yes
Data Execution Prevention Available: Yes
No this,
In rhino Type, SystemInfo and copy paste items here, I’m trying to figure out if another plugin is causing the issue
If i recall the excel needs to be closed in order to read it.
Maybe you are using 32 bit excel, change to 64 bit try!
Rhino 6 SR35 2021-8-10 (Rhino 6, 6.35.21222.17001, Git hash:master @ 073ac7b225c67348731c6597127b9410126c3139)
License type: Educational, build 2021-08-10
License details: Cloud Zoo. In use by: Vijesh Kumar V ()
Windows 10.0.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: VIJUSPIDER
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 6-1-2021 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1660 Ti (NVidia) Memory: 6GB, Driver date: 5-2-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 512.72
> Integrated acclerated graphics device with 4 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-2-2022
Driver Version: 30.0.15.1272
Z-Buffer depth: 24 bits
Total Video Memory: 6 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 6.35.21222.17001
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.35.21222.17001
am using 64bit
closed and only read.
Hi -
Have you tried any of the other Excel reader plug-ins for Grasshopper? → BROWSE | Food4Rhino
One user especially liked NPOI:
