Akash
September 9, 2023, 7:11pm
1
An annoying bug, nothing critical, but quite annoying.
and it may be true with other panels, [didn’t check]
When typing a number, [to change a value] after the first digit, the focus is usually lost and the command prompt appears and tries to execute a command from the next digits [I use the floating command,]
Also while renaming a material, deleting some characters from the name, I got the command popping asking if I’m sure I want to delete the material …
Edit: today again trying to rename materials. if I select the text and type something else it works. But then, when selecting superfluous text and trying to delete it, Rhino delete the whole material instead.
Please kindly put it on the to fix pile
thanks a lot
akash
Gijs
(Gijs de Zwart)
September 27, 2023, 9:23am
2
hi @Akash is this still and issue for you? I could not repeat any of the issues you are describing here.
If it is, pls run _SystemInfo and post back the results, thanks
Akash
September 27, 2023, 2:38pm
3
Yes I can repeat it
But with adding values in a Bella material,
in a raytrace material I was not [on a quick try] able to reproduce it.
with a Bella material:
add a material [dialectic has many options to change values]
start typing values in one of the available spaces…
first number will go in the value slot, but 2nd digit will evoke the floating command search and will go in there.
I can try harder to reproduce it with non Bella materials later when I have some more time…
thanks a lot
Akash
SystemInfo
Summary
Rhino 8 SR0 2023-9-26 (Rhino 8 BETA, 8.0.23269.15064, Git hash:master @ e4cc5068632f42fb560d3418a2112465b4a0acec)
License type: Commercial, build 2023-09-26
License details: Cloud Zoo
Expires on: 2023-11-10
Apple macOS Version 13.5.2 (Build 22G91) (Physical RAM: 96Gb)
Mac Model Identifier: Mac14,6
Language: en-TH (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Max
Color LCD (1728 x 1117 @ 120.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/usd/libIex.dylib
/usr/lib/usd/libHalf.dylib
/usr/lib/usd/libAlembic.dylib
/usr/lib/usd/libusd_ms.dylib
/usr/lib/usd/libosdCPU.dylib
/usr/lib/usd/libImath.dylib
/usr/lib/usd/libIlmThread.dylib
/usr/lib/usd/libIexMath.dylib
/usr/lib/usd/libtbb.dylib
/usr/lib/usd/libMaterialXCore.dylib
/usr/lib/usd/libMaterialXFormat.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/usr/lib/swift/libswiftExtensionFoundation.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftExtensionKit.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftMapKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp/libbella_dotnet_native.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/IntelDenoiser/0.6.7/libtbb.12.dylib
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/IntelDenoiser/0.6.7/libOpenImageDenoise.1.4.3.dylib
/Applications/RhinoBETA.app/Contents/PlugIns/import_modelio_macos.rhp “Model IO Import” 8.0.23269.1002
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/bella_rhino.rhp “Bella” 23.4.0.0
/Users/akashlotan/Library/Application Support/McNeel/Rhinoceros/packages/8.0/IntelDenoiser/0.6.7/IntelDenoiser.Mac.rhp “IntelDenoiser.Mac” 1.0.0.0
/Applications/RhinoBETA.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_OBJ.rhp “Import_OBJ” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_XAML.rhp “export_xaml” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/QuadRemesh.rhp “QuadRemesh” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_OBJ.rhp “export_OBJ” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_glTF.rhp “Import glTF” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/ShrinkWrap.rhp “ShrinkWrap” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_SVG.rhp “Export SVG” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_glTF.rhp “Export glTF” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_DAE.rhp “Export_DAE” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PDF.rhp “PDF Export” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_IGES.rhp “IGES Export Plug-in” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_SVG.rhp “Import_SVG” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/BlockEdit.rhp “BlockEdit” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Export_AMF.rhp “Export_AMF” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/import_DST.rhp “Import_DST” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/export_PLY.rhp “PLY - Polygon File Format Export” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Import_AMF.rhp “Import_AMF” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/PlugIns/export_SKP.rhp “SketchUp Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_UDO.rhp “Moray Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_RAW.rhp “RAW Triangle Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_USD.rhp “Export USD” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Import_DGN.rhp “MicroStation file import: import_DGN” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_E57.rhp “E57 Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_VRML.rhp “VRML Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Import_WAMIT.rhp “WAMIT import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_SKP.rhp “SketchUp Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_RAW.rhp “Raw Triangles Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/MPlane.rhp “MPlane” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_XGL.rhp “XGL Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_CD.rhp “Cult3D Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_LWO.rhp “Lightwave Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_SLC.rhp “SLC Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_3MF.rhp “import_3MF” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_STEP.rhp “STEP Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_3MF.rhp “export_3MF” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_WAMIT.rhp “WAMIT Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Import_SLC.rhp “SLC Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Import_OFF.rhp “OFF Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Squish.rhp “Squish” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_X_T.rhp “Parasolid Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/RhinoLabsTools.rhp “Rhino Labs Tools” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Import_M.rhp “Import_M” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Import_X.rhp “X Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_IGES.rhp “IGES Import Plug-in” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_AI.rhp “Adobe Illustrator Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_ACAD.rhp “AutoCAD file export : export_ACAD” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_LWO.rhp “Lightwave Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_SAT.rhp “ACIS Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_CSV.rhp “Comma Separated Value Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_PDF.rhp “PDFReader” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_STL.rhp “STL Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_VDA.rhp “VDA Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_STEP.rhp “STEP Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_FBX.rhp “Export_FBX” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Import_SolidWorks.rhp “Solidworks Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_STL.rhp “STL Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_RIB.rhp “Renderman Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_FBX.rhp “Import_FBX” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_Points.rhp “Points Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_VDA.rhp “VDA Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_ACAD.rhp “AutoCAD file import: import_ACAD” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_X.rhp “X Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/CreaseAngle.rhp “CreaseAngle” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_3DS.rhp “3D Studio Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_PLY.rhp “PLY - Polygon File Format Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/MeshTools.rhp “MeshTools” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/import_Points.rhp “Points Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/MeshFromPoints.rhp “MeshFromPoints” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/export_VRML.rhp “VRML/X3D Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Import_GTS.rhp “GTS Triangle Import” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/SolidTools.rhp “SolidTools” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_GTS.rhp “GTS Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/PlugIns/Export_POV.rhp “POV-Ray Export” 8.0.23269.1002
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.0.23269.15064
/Applications/RhinoBETA.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.0.23269.15064
Gijs
(Gijs de Zwart)
September 27, 2023, 2:40pm
4
@jdhill is this something you are aware of?
jdhill
September 27, 2023, 2:42pm
5
no, but I’ll check it out
jdhill
September 27, 2023, 3:03pm
6
yeah there is something funky on macos, I’ll see what’s going on
