I’m sure the answer is obvious but …
When ray tracing is set to Final Quality is there a stop button?
When you’re rendering in the viewport is there a Save Image button?
Hi Alex,
If you’re rendering to the raytraced viewport, it stops after the sampling level has been reached. You can set that sampling level using the command RhinoCycles_ChangeSamples command while beeing in raytraced viewport.
Yes, use either ViewCaptureToClipboard or ViewCaptureToFile. For renderings larger than the maximum viewport size you need to download and install the Cycles Plugin from here which allows to use the regular Render command. Note that this is still work in progress.
c.
As an addendum to previous message: in the HUD there should be a Pause button that you can click to pause an ongoing render. Once clicked it should turn into a Play button. I noticed some drawing errors with the buttons in the HUD. I created an issue for @andy to look at.
/Nathan
