Hello all,
for a 3D print I need 2 closed surfaces. Unfortunately I can’t get the polygon meshes to be 2 single closed polygon surfaces. It should still be 2 flat, but completely closed. Can someone help me?
Roof.3dm (977.6 KB)
Hello all,
the grey object has some holes, simply join all of it together and use FillMeshHoles.
the red object consists of a polysurface (grey) and mesh (red) that will not work. for a quick fix to print delete the grey side part and use the same command pointed out above or fillmeshhole.
