Hi All,
I am trying to twist a curve in grasshopper to create a parametric louvres effect. The original surface is not planar and is a network surface. The script works perfectly on a planar surface but not on mine. Any help provided would be amazing. I have attached references below to show how it worked with the planar surface for comparison. You will see where the surface is mirrored the twists do not meet.
Thanks,
Fin
Twist Curves.3dm (51.0 KB) Twist Curves.gh (12.6 KB)
